difference between 2.95 vs. 3.35 trans grear set?
Whats the difference in the 2.95 vs. 3.35 gear sets in the T-5?
which one is better and what are the pros and cons of each
and how would one or the other behave with either 3.73 or 4.10 read-end?
Thanks!
Thanks!
Just a guess- albeit an educated one, 3.35 would accelerate faster than 2.95 but have a lower top-speed (in first). and would probably be more reasonable with a 3.73 or even 3.55 differential gearing.
How do you find out what tranny gears you have?
I looked it up on a speed chart calculator thing
basically your going to get right around 6mph more in first gear versus the stock 3.35 @6000rpms
I would say it would be better if you were racing it all the time, that way you would have a little more first gear, and your be shifting into a little higher rpm into second.
just driving around town now with the 3.35 sometimes bogs on me a little if im not paying attention, then again I have a nice grippy clutch
for the dragstrip the 3.35 first is better for launches
i rally would rather have the 2.95. i have 3.73s and currently i have to shift to 2nd about 5 ft into the intersection. the 2.95 (combined w/ my 3.73s) would get me a little farther and as an added benefit, would likely help launches on street tires
