HELP
I HAVE AN "88 GT 5.0 STANDARD, I HAVE RELACED THE ERG VALVE, SENSOR, AND VACUUM SOLENOID. THEN I HAVE RUN A SELF TEST COMPUTER ON THE CAR AND THE CODE I GET SAYS AS FOLLOWS:
ERG VALVE SENSOR OR PRESSURE FEEDBACK ERG (PFE) SENSOR - SIGNAL VOLTAGE IS BELOW MINIMUM SPEC.
OR
EGR VACUUM REGULATOR SOLENOID CIRCUIT PROBLEMS
OR
EGR VALVE IS NOT IN ITS NORMAL CLOSED POSITION
ALSO PLEASE TELL ME HOW TO RESET MY COMPUTER 'CAUSE THAT COULD ALSO BE MY PROBLEM
OR
OR
First off there should be an option on your scanner to reset the computer. On mine there is a button that says reset. On yours you might have to press something else. Read the manual for it. As far as the EGR problem, check the vacum lines going to the EGR. Sometimes they get hard from the heat and collapse or break. Mine are under a black housing so I could not see it right away. i had the same codes and it was driving me nuts. Finally I pulled the vacum lines and the one which goes on top of the EGR was broke in half by the intake.
removing the negative battery cable and waiting a minute then reinstalling it will reset the computer. the voltage from most all the sensors is 0-5 volts, so see what the voltage is coming out of your EGR, 0.9 is closed and 5 is wide open I think. if you're not getting any voltage, check for broken wires in the harness going to/from the valve positioner which sends the signal to the computer. with 0 vacuum, the valve is closed and higher vacuum opens it up.
i have reset my computer, sprayed carb cleaner all around the vacuum lines, and i have not found the problem. so i ran the self test computer on the car again and i'm still getting the same code. the car runs like junk. it's like it falls on its face. just like a lose of horse power.
pull the EGR valve back off and see if it is stuck in the open position. with it off, the cone tip of the valve should be sticking out past the flange where it bolts up. if not, then you need to clean it with some carb cleaner and free it up if it's stuck. the valve has a spring to keep it closed and vacuum is what opens it up. also check the wiring to the plug on the top of the valve and make sure the connections are clean and tight and check the voltage. should be less than 1 volt with valve closed and 5 volts with it open all the way.
