ALT PROBLEM
Hey guys, my stock alternator just isnt cutting it. The guy I got it from put u/d pullies on the car and that made the problem even worse. So I decided to upgrade to 3g ASAP. this guy is selling this alternator on ebay, does it sound good to you?
"Included With This Kit:
- Remanufactured 3G alternator w/ 1-3/4" over drive pulley. This the same alternator as the Ford Racing/Robert Yates developed, Motor Sport part # M-100300-A351. This alternator doesN'T require the alternator bracket be modified (direct bolt in).
- New.. ANL style fuse holder
- New.. ANL 200 AMP fuse
- New.. econo stator connector.
- New...7 feet, cut to proper length of audio grade/oxygen free, fine strand, 4 gauge copper wire w/ the needed 5/16" loop terminals tool crimp mounted, heat shrink covered at connections, and wire loom protection over the length of the power cable.. (Picture #3 shows the power wire, assembled for your convenience)
- New... ring terminals and butt connector
- New.. bolt
- New.. Easy to follow instructions"
and if its good, how much should i pay for it? Thank you
- New.. bolt
well it says its a refurbished small case alt so it wouldn't need the bracket cut, which I would do if i needed to anyway. But the reason I like it is b/c it comes with everything I need to do the whole swap, fuses, everything.
Ohhh OK. Well, if those are your plans than the new alternator will be a good upgrade but if not you can get stock pulleys anywhere for very cheap (ebay, junkyards, forums, etc. etc. etc.)
stangin1996gt
Sep 21, 2015 11:01 AM
