fuse problems
Old Jun 15, 2006 | 06:45 PM
sultan68's Avatar
sultan68
Default fuse problems
my horn doesn't work and when I try to put a new fuse in it tries to blow it..any ideas what's causing this? any help appreciated
thanks
Old Jun 15, 2006 | 06:57 PM
kevstang87's Avatar
kevstang87
Default RE: fuse problems
you have a short some where
Old Jun 15, 2006 | 08:57 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: kevstang87
Yep yep! Is there a coin stuck in your cig lighter. Seen it a 100 times! If not, unplug the horns and then try it. If it doesn't blow, one of the horns is shorted. If it still blows, there is a short somewhere in between.
Old Jun 15, 2006 | 09:58 PM
5.0_faithful's Avatar
5.0_faithful
ORIGINAL: PRO50SC
I had same exact problem. One or both of your horns is shorted causing your fuse to blow. Replace both horns to be on the safe side because one of mine was bad and the other had a small short which was a little hard to find at first. So replace both or get one good one by NAPA or the likes and you'll be good again!
jma2
Jul 10, 2023 01:00 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
wenmill
Sep 11, 2015 07:07 AM
cbird1177711
Sep 2, 2015 04:12 PM
