hard to shift
Old Jun 23, 2006 | 09:37 PM
5Liter Import Eater's Avatar
5Liter Import Eater
Default hard to shift
ok here's my problem.. after driving for about 45 min or longer, the shifts get real hard to shift, like they don't want to go in. i have to push the clutch down as far as possible as hard as i can and its a little easier, can the clutch need adjustment? or can something be wrong with the tranny? the ford racing clutch was just put in about a year ago, if that. i also have a pro 50 shifter that i put in about year ago as well. its fine when i dont drive that long, but after driving for a while is when it starts. the tranny is stock and i have 373 gears in the rear. it has 111,000 miles and in mint condition, this is the only problem i have... any help is appreciated, thanks
Old Jun 23, 2006 | 10:03 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: hard to shift
Check the fluid and if it has never been changed, start w/ that.
Old Jun 23, 2006 | 10:19 PM
TENGRAM's Avatar
TENGRAM
take the clutch fork cover off and check for slack in the cable. it shoudn't be real tight but it needs to have a little tension.
Old Jun 23, 2006 | 10:36 PM
5Liter Import Eater
how do u check the fluid on a manual trans?
Old Jun 23, 2006 | 10:58 PM
tcwc's Avatar
tcwc
My clutch was VERY hard to push in (but this was ALL the time). The problem turned out to be a bent clutch fork. It don't sound the same as your problem, but you might want to keep it in mind. Hope this helps.
Old Jun 23, 2006 | 11:02 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: 5Liter Import Eater
There is a plug in each side of the trans. 1 for fill, the 1 mounted high, and 1 for drain, the 1 mounted low. Kinda makes sense huh?
Old Jun 23, 2006 | 11:09 PM
5Liter Import Eater
so how will i know if its full, can u see inside? or should i just put fluid in the top until its full
Old Jun 23, 2006 | 11:14 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Stick your pinky in and if you feel fluid it's full. But like I said, if it's never been changed, with the mileage on it, I would change it.
Old Jun 23, 2006 | 11:16 PM
5Liter Import Eater
well the clutch was replaced last year, i took it to a shop, wouldnt they have changed it when they changed the clutch
Old Jun 23, 2006 | 11:18 PM
tcwc's Avatar
tcwc
When the shop did my clutch a couple months back, I had to TELL them to do it (they were not going too). Might want to check with them or just replace it.
