fuel pump replacement question
Old Jun 25, 2006 | 05:10 AM
Hung Like a Stang's Avatar
Hung Like a Stang
Default fuel pump replacement question
alright, So I thought I should change my fuel pump, sweet idea right??
Okay, well, I get it in, get the tank up and I start it up, it ran, but there was a leak. So I take the tank back down (stupid, inexperienced me bolted it up) think I fix the leak and put it back in. sure enough, it starts right up and I let it run for a few just to be sure there's no leak and still to my knowledge there isn't. So I get in the car, take it up the street, and without any warning, it dies. Just stops. I have no idea why!!!
Is it possible to cross the fuel lines that go into the tank? I thought they were size specific (the smaller hose won't fit on the bigger inlet) But if so would that be my problem. But why would it run for minutes and then die? Thanks in advance guys.
Old Jun 25, 2006 | 05:34 AM
lookinforastang's Avatar
lookinforastang
I ♥ Acer
Default RE: fuel pump replacement question
u check the pressure?
Old Jun 25, 2006 | 05:36 AM
Hung Like a Stang
that I havn't done yet (it just happend like a half hour ago and its 2:30 in the morning) I don't see How I'd lose fuel pressure like that though, like I said, it ran for a few minutes, I started it up multiple times, and went up the street.
Old Jun 25, 2006 | 06:23 AM
5.0 MPG's Avatar
5.0 MPG
give us something to work with here? can you hear the pump spinning? if its not then check the relay first then if you hear it clicking you may have a bad contact on your pump. It happened to me.
Old Jun 25, 2006 | 11:51 AM
FordMustangXBA's Avatar
FordMustangXBA
Yeah, do you hear it buzz when you first turn the key to ON before starting the car?
Old Jun 25, 2006 | 02:42 PM
Hung Like a Stang
yeah, I mean, it was honestly WORKING fine. I turned the key a few times after it died trying to get it to pump more fuel into thinking maybe it lost its prime or whatever going up a hill. But I had no luck. the pump is spinning fine, but no start.
Old Jun 25, 2006 | 05:56 PM
Hung Like a Stang
welp, I pressed in the needle on the schrader valve, and we got fuel in the lines. So then we knew it had to be ignition problems. We checked, and I wasn't get spark at the plugs. I changed my ignition module on the distributor, I got spark at the coil, but no fire. So I tried an injector pulse test with a test light and AHA! No light! So that means the processer in the dizzy is cashed. So I'm just gonna replace the whole dizzy. I knew I didn't mess up on the fuel pump!
Old Jun 25, 2006 | 05:58 PM
All4n's Avatar
All4n
since this thread is about fuel pumps.. mine is really loud while idling... is that common or is that something to think about replacing the fuel pump?
ALSO: anyone know what the stock LPH is?
Old Jun 26, 2006 | 02:07 AM
Hung Like a Stang
I don't know about the buzzing question. But Stock is 95 lph
Old Jun 26, 2006 | 05:13 PM
All4n's Avatar
All4n
okay cool, thanks.
