clocking MAF
Old Jun 26, 2006 | 07:50 PM
HACKGT350's Avatar
HACKGT350
Default clocking MAF
my friend has a 90 gt and his idle is all messed up how do you clock the MAF i have read that it helps the idle or is it something else?
Old Jun 26, 2006 | 08:55 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: clocking MAF
Take a piece of masking take and make marks on it evenly spaced apart and wrap it around the intake hose. Make 1 mark on the mass air and start rotating the meter until you find the "sweet" spot. That's it, you're done.
If it's all stock I doubt very seriously it will have any affect.
Old Jun 26, 2006 | 09:44 PM
HACKGT350's Avatar
HACKGT350
thanks pro...do you think it could be anything else?
Old Jun 26, 2006 | 09:47 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: HACKGT350
What has he done to the car? Mods? Did this just start? Has he done anything to cause the problem? Need more info on the problem. Could be alot of things causing it.
Old Jun 26, 2006 | 09:48 PM
HACKGT350's Avatar
HACKGT350
hes got heads they were on the car when he bought it. it had a slight jump in the idle when he first got it now its just all over the place and sometimes stallls
Old Jun 26, 2006 | 09:52 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: HACKGT350
Things to check,
Vacuum leaks, egr valve stuck open, dirty IAC motor, dirty throttle body. How does it run except for the idle?
Old Jun 26, 2006 | 09:57 PM
HACKGT350's Avatar
HACKGT350
it runs great very quick car
Old Jun 26, 2006 | 09:59 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Look at the areas I suggested.
Old Jun 26, 2006 | 10:00 PM
HACKGT350's Avatar
HACKGT350
ok thanks PRO are you going to cj pony parts on the 8th? i wanna see you notch and touch it maybe stick my finger in its tail pipe haha
Old Jun 26, 2006 | 10:01 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: HACKGT350
LOL! Too far of a drive for me.
