AOD?
Old Jul 2, 2006 | 11:23 PM
04gtstang's Avatar
04gtstang
Default AOD?
Is the AOD the stock automatic transmission or is it an aftermarket? How much power can it handle?...Also what is the stock compression on a 5.0 engine?
Old Jul 2, 2006 | 11:27 PM
Stevens91gt's Avatar
Stevens91gt
Default RE: AOD?
it is the stock tranny
350-400hp maybe..it's more of a guess
Old Jul 2, 2006 | 11:57 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: AOD?
aod is the stock auto from '85-'93
what can it handle ???? w/ nothing at all done to it, the stock motor is too much for it.
od band is too small, shift points are too low, oiling is for ****, and the gearing sux
i went through 3 aod's on my '90 GT that i bought brand new, and never went faster than 14.30 or so
i believe stock compression is 9:1
Old Jul 3, 2006 | 12:08 AM
FullAuto's Avatar
FullAuto
Default RE: AOD?
Stock they suck. But I did make >600rwhp through a built one. However, I wouldn't spend that kind of money on one again.
Old Jul 3, 2006 | 02:10 AM
88BlueGT's Avatar
88BlueGT
Default RE: AOD?
Like everyone else said.... stock AOD; the stock motor puts out too much power for it. Mostly everything about them is sh*tty. If its a weekend car or something like that you could upgrade to a C4 (no overdrive thats why I said weekend car) or you can upgrade to a Lentech or something in that area. You can get a Lentech Street Bruiser w/ a custom stall for around $2,300. The tranny is also good for around 500-550 horsepower.
Old Jul 3, 2006 | 02:18 AM
04gtstang's Avatar
04gtstang
Default RE: AOD?
thanxs guys lots of help
Old Jul 3, 2006 | 02:20 AM
ballzoutstang875.0's Avatar
ballzoutstang875.0
Default RE: AOD?
auto's I hear can handle more than the suggested 300 hp than the t-5's. however, the aod's still suck *****. unless u were to put in a stall or something like a ratchet shift kit. the're really weak and easy to break something.
Old Jul 3, 2006 | 02:47 AM
hellas85stang's Avatar
hellas85stang
Default RE: AOD?
some thing is wrong then i have a aod and a tci shift kit, and a slap shifter and if you learn to shift right u dont have to shift into od..a good rebuilt aod can handle 350 hp all day long...if u use like high energy clutches and band...a stock aod i have had them go along time on 350 hp...thats with occasional nitro too...lotsa folks build trannys but justa few build them right...
Old Jul 3, 2006 | 05:29 AM
FivePointGo's Avatar
FivePointGo
Default RE: AOD?
The AOD in the Fox Mustangs are prone to O/D failure.
Old Jul 3, 2006 | 09:20 AM
OJMiles's Avatar
OJMiles
Default RE: AOD?
Theres several companies that reman the AODs to handle high(er) HP applications and still retain overdrive function.... TCI, Performance Automatic, Lentech, etc... are a few that come to mind. Some companies reman them for very high HP applications, but alot of times they do away with the overdrive function... if you're going to do that you might as well get a C4... they're lighter.
Main things these transmissions replace are the bands with kevlar ones, they add more and stronger clutches to the drumpacks. Many times they also add a stronger input shaft and replace the valvebody or add a (real) shift kit to the stock one. All this should easily make it good for over 300hp and still maintain overdrive functionality.
ojm
