I need help with a starting problem
Old Jul 6, 2006 | 12:55 AM
kgrover21's Avatar
kgrover21
Default I need help with a starting problem
I have a 90 mustang with a 306, full msd ignition, blaster coil, new starter, and a new seliniod. When I turn the key over the selinoid clicks rapidly and the starter doesn't seem th engage the flywheel. Could it possably be the ground on the selinoid. Any help or ideas would really help. Thanks.
Old Jul 6, 2006 | 03:27 AM
Hung Like a Stang's Avatar
Hung Like a Stang
Default RE: I need help with a starting problem
eh, could be the bendix isn't kicking out on starter, just cause its new doesn't mean its good you know. I'd do some quick checks just to make sure you're getting fire, pull coil wire, and plug wire. then I'd bypass msd. I'd also just push in the needle on the schrader valve just to be certain there's fuel. Then, I'd do an injector pulse test with a test light, Pull the injector, stick the test light in, and turn it over, if you have no blinking light, its the processor inside your dizzy not sending signal to the injector to realese fuel might as well replace the whole dizzy.. That will all take like 5 minutes to do those tests, and if its all good, then its probalby starter.
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
cvarner131
Aug 17, 2015 07:38 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
