waterpump problem
Old Jul 6, 2006 | 06:57 PM
boooosted's Avatar
boooosted
Default waterpump problem
anybody have any problems with aluminum water pump? I bought one and a new timing cover and put it all back together and the waterpump is leaking near the two bolts at the bottom that hold on that aluminum plate. I was told they are notorious for leaking... is this true. If so what should I do besides the standard gasket and sylicone?
Old Jul 6, 2006 | 07:37 PM
sdmaker's Avatar
sdmaker
Default RE: waterpump problem
gasket high temp rtv silicone, and thread sealer on the bolts.
1fastzook's Avatar
1fastzook
i would sugget just getting some new fel pro gaskets and use some silicone or some hi tack spary and try it again.I have a chrome water pump and i used the gaskets that came with it and it leaked like a bi*ch.i put some fel pros + some hi tack and never had a leak again.unless some how your TC cover is warped
Old Jul 6, 2006 | 07:46 PM
5IVE.OH's Avatar
5IVE.OH
There are two different gaskets for the water pumps, make sure you used the ones for a HO engine. I had this problem awhile back with a hacked together motor.
Old Jul 6, 2006 | 07:47 PM
P Zero's Avatar
P Zero
Make sure you let the silicone cure, 24hrs.
-P.
Old Jul 6, 2006 | 08:53 PM
86HOGT's Avatar
86HOGT
I used no silicone and cleaned the surfaces real well and using Fel-Pro gasket. If you do need to seal it use "The Right Stuff" sealer, then you can run it right away.
Old Jul 6, 2006 | 10:08 PM
silver91gt's Avatar
silver91gt
hi there, some manufacturers make the heads of the 2 bolts that hold on the backing plate too long and it bends out the bottom of the pump making it leak.
grind down the tops of the bolts and use silicone as well as the gaskets.
I like permatex ultra black, you can reassemble it and fill it and it wont leak.
the right stuff gasket maker is good, but I find it dries too fast.
Old Jul 6, 2006 | 10:14 PM
Jay5oh's Avatar
Jay5oh
I ♥ Acer
Thread sealer on the bolts, check the gaskets.
Seanam
Oct 4, 2015 10:15 AM
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
