How to set idle?
Is there anyway to really set the idle on my car? I know it's computer controlled, so I wasn't sure if there was a manual way to do it or not.
The reason I'm asking is because on the installation instructions on the bbk pullies, it says to set the idle at 750-800 rpm. |
RE: How to set idle?
stock idle is around there anyway
ive heard u adjust it by turning the screw under the tb but u also have to reset the tps voltage or something like that? sorry im not too technical just going off of what ive read here in the past hopefully someone else can chime in |
yep, he's right. adjust the screw under the throttlebody per These Instructions and then continue on to step 4 to adjust TPS voltage (set it anywhere between .8 and 1.0vdc).
