starter problems on 5.0
Old May 14, 2004 | 05:17 PM
five0man's Avatar
five0man
Default starter problems on 5.0
hi,
i have a 1984 mustang vert, the person i got it from replaced the 4-banger with a '89 5.0. The problem i am having is it won't turn over. I have replaced the starter motor and when it turned over the starter motor didnt stop running. I have put a new starter solenoid on it. The manual talks about a fuseable link? Could this be the problem?
Thanks for any help!
Old May 14, 2004 | 05:22 PM
50fiend's Avatar
50fiend
Default RE: starter problems on 5.0
If the motor is turnin over but there is no spark it could be.
Old May 14, 2004 | 05:27 PM
five0man's Avatar
five0man
after i replaced the starter it turned over, but while it was running the starter motor continued to run. (even with the key out) until the starter burned up.
96SilverLT1's Avatar
96SilverLT1
i'm a little lost. you replaced the starter and then when you tried to start it the starter would not stop spinning? it;s posible that the Ign switch is shorting and letting voltage feed through the selinoid wire to the starter. can you disribe the problem a little more?
Old May 14, 2004 | 05:29 PM
50fiend's Avatar
50fiend
That not a fusible link problem. If it was, the starter wouldn't be getting any current. Somehow the current isn't being disconnected.
Old May 14, 2004 | 05:55 PM
five0man's Avatar
five0man
do you have an idea what could be keeping the current open?
Old May 14, 2004 | 05:59 PM
96SilverLT1
does it only stay engauged after you try starting it or just when you turn the key on or what? if it's on all the time when the battery is on you could have the main feed and the selinoid wires touching at the starter. you said you had the seliniod rebiuld. it;s poiible thats causing it. you need to get under there and see if there is power on the small selinoid wire when the key is off. if the power shuts off when the key goes off it;s internal in the starter. if it stays on I would start with the IGN switch
Old May 14, 2004 | 06:00 PM
five0man's Avatar
five0man
yea thats what happened and it didn't cut off (the key was out of the ignition) until the starter burned up. the solenoid clicks and thats it. what more would you like to know?
From the start of the problem
when the problem started both the hot and ground wires coming off of the battery were hot, smoke was coming from the starter solenoid (from fuseable link wire). replaced solenoid and starter motor, when i went to crank the car it turned over, and starter motor kept spinning, when I took the key out it still spun until it burned up.
Old May 14, 2004 | 09:37 PM
VertStangGT86's Avatar
VertStangGT86
If the link was smoking you should check it for continuity cause you'll need that either way.
Old May 14, 2004 | 09:51 PM
five0man's Avatar
five0man
Thank you for the help. It is much appreciated.
