lunching
Well alot depends on your car's set up. tires ect.. I go at 3000. I have Nitto's on mine but i dont launch at Full pedal either once in second i go full. Street tires Try around 2200 to 2500 rpm
thx cool anyone else and do i just reve the engine at like 2300rpms and let the cluth out when light goes green do i pop it or slide ir out
POP=Take ur foot right off
Slide=Bring it out normal shifting not speed shifting
dont take any ofence to this if u kno those 2 terms someppl dont so i thought i would inform
If you dump the clutch you'll either blow away your tires or bog down, so slip it intially. After you come off the line you can let it out right away and modulate the throttle or mash the gas & modulate the clutch.
so basicly just let it out slowly and then soon as im moving a bit just pop the clutch but do i keep it reved at 2300rpms and let it out slowly then once moving a lil pop it or what
