Engine swap....And now problems. HELP!!!
Old Jul 18, 2006 | 02:00 PM
1994sn95's Avatar
1994sn95
Default RE: Engine swap....And now problems. HELP!!!
ok the cap and rotor are also new...i put them on the motor when it was in my old car and it was used for about a month. The fuel isnt too old, maybe about a month or a little less. the filter is alos brand new. the wires shouldnt be bad because they were workin good a couple weeks ago on the motor i blew. i have not pulled any codes on it yet because i would have to take it to a shop for that and i wanna see if i can fix it myself first. it doesnt really seem like its backfiring, more like a misifire or something. very rough is the best way i can describe it. and i have went over the firing order many times makin sure all the wires are on the right cylinders.
and as for the smog i removed the pump and the big tube that comes out of it. and sealed up the back up the heads.
my guess would be vacuum too. how were u sayin to check for that? i was thinkin too just hook up a boost gauge.
Old Jul 18, 2006 | 02:12 PM
1994sn95's Avatar
1994sn95
hey guys im gonna be away for the next day and probably wont have acess to a comp. soo any other questions u have or suggestions please post them and i will answer all tmrw.
Old Jul 18, 2006 | 03:37 PM
I G Joe's Avatar
I G Joe
i would defintely check for vacuum leaks. also check your MAF maybe it isnt working correctly and its causing the engine to dump little or alot of fuel in causing it to run rough. theres lots of variables to go by. if we only had a video to see how it was running.
Old Jul 19, 2006 | 06:30 PM
1994sn95's Avatar
1994sn95
how would u guys suggest to check for vacuum leaks? the only way i could think of was a boost gauge. i will try and get a video for u of it running.
Old Jul 19, 2006 | 07:11 PM
mrbigshot's Avatar
mrbigshot
take carb cleaner or starting fluid and spray it around the vacume hoses and around the t body and intake gaskets (even base). if the engines rpm changes than you will have found a leak.
Old Jul 19, 2006 | 07:21 PM
SD_LX_5.0's Avatar
SD_LX_5.0
If you are still running the stock coil those bosh platinum 4s you say your running are the problem, even the platinum 2s are almost too much for the stock coil and dizzy to handle..
The platinum fours will pretty much only work in stock applicstions when its a coil over plug set-up.
Buy some cheep platinum 1s or autolites and MAKE SURE THE GAP IS CORRECT before installing. If you checked all you vacume leaks and your intakes are properly tightened and sealed this will probly solve the problem.. you'll be surprised trust me..
Old Jul 19, 2006 | 08:16 PM
taurus gt man's Avatar
taurus gt man
Remember stock ignition components are always recommended as aftermarket can pose problems on occasion. Anyway it definately sounds like a vacuum leak somewhere. And you should be able to run free diagnostics at autozone. Chris
Old Jul 20, 2006 | 01:51 PM
1994sn95's Avatar
1994sn95
thanks guys i will go try all those things right now and let u know how it goes. as for the plugs...my old motor has some motocraft platinums in it and they ran fine before it blew. should i try those?
Old Jul 20, 2006 | 02:06 PM
92hatchLX's Avatar
92hatchLX
Get rid of those bosch platinums asap!!! make sure that your plug wires aren't burnt through, is the coil stock or do you have a newer one in there?
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
zanemoseley
Sep 6, 2015 12:58 PM
