Cam trouble help!!
ok....i just installed a XE268 comp cams cam last weekend....now i just got a oil pan and im installing that...the engine is out of the car and while i was scrapping the gasket sealer off i noticed the cam journals were sticking out one side about a little less than a 1/4"....since the journals were a little off center the cam lobes werent directly centered with the lifters....will i need to take everything back off and move the cam the extra 1/4" back?? or is there somthing else i dont know of???? and also would i be able to use silicone gasket maker instead of a oil pan gasket?
The camshaft thrust plate should take care of the install. If you can't get the thrust plate on, you have a problem. Do you have the right cam for your motor?
Quality control at Comp Cams should catch a bad grind.
the thrust plate went on fine and yea i ordered a comp cams 351w cam and the recete that came w/ the cam read it was for a 351w. do you think if i put in the distributor, and the gears line up w/ no problems then it will be fine?
ORIGINAL: redrum93
You have a 5.0 block right? What year is it? That cam is for Hydralic ROLLER Lifters right?
I looked on the Comp Cams website, and the XE 268H is for hydralic FLAT tappets, on a 351W motor. You need a cam for a 5.0 block. There isn't a 268 for a 5.0 block. Double check.
http://compcams.com/Technical/Curren...HTML/82-91.asp
http://compcams.com/Technical/Curren...HTML/76-81.asp
i have a 351w sorry for not mentioning it....heres some pics of what it looks like.....
http://www.cardomain.com/memberpage/356176/4
(page 4)
is that how its sopposed to be??
(page 4)
