Power Steering Pump Help!
I recently installed a kenne bell. I took the car on a test drive. I floored It in 3rd, went to 4th.
All of a sudden the car died. I pull over, raise the hood, and see power steering fluid every where. I didnt over fill it, cap was on tight, so what could the problem be?
it could be a number of things. What i would do is steam everything off clean, fill it back up and check for a leak. If the leak is a line or something, you will see the fluid pouring out. Start off there and see what happens.
uberstang1
Sep 20, 2015 06:42 PM
