Error Code 172
Old Jun 4, 2004 | 03:04 AM
tchamber's Avatar
tchamber
Default Error Code 172
Hey all, I have a code reader for my 95GT, and it says I'm running lean with code 172, and I checked my Haynes, and they say it's a problem with my Oxygen system, but when I back-probed both sensors, they were A-OK. Checked MAF just to be safe, and it's OK also. What could be causing this, do any of you know?
Old Jun 4, 2004 | 03:13 AM
MelloYello's Avatar
MelloYello
Default RE: Error Code 172
might have a bad pcm sensor have you messed with the timing at all?
Old Jun 4, 2004 | 03:31 AM
tchamber's Avatar
tchamber
Nope, never messed with timing, but the car has 110k on it, and going strong. Both O2 sensors are new.
Old Jun 4, 2004 | 05:45 AM
Fox 5.0's Avatar
Fox 5.0
Do they make scanners for OBD1? or whatever its called? i wanna get one for my fox...
Old Jun 4, 2004 | 06:23 AM
tchamber's Avatar
tchamber
Yeah, I have one, it scans both OBD1 and 2, cost about 210, called Auto X-Ray.
Old Jun 4, 2004 | 10:41 AM
WNDSOR's Avatar
WNDSOR
i've found that unhooking your battery, for say 4 hrs, then hook it back up and run it seems to do some good. it resets everything and programs it. you might think its crazy and even if you unhooked it to put the new o2's on, it sitll might help if you do it for a prolonged period. just a thought, cant hurt, i do that on my gt and f250 everyonce in a while, the engine light might come on after driving for a minute but keep going it will go off.
Old Jun 4, 2004 | 07:47 PM
95stang's Avatar
95stang
Mine had lean on both banks, even w/ new O2's, ended up being a dirty MAF sensor. You can get low cost OBD 1 scanners at WalMart and Autozone 25-30 bucks.
Old Jun 4, 2004 | 07:52 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
or you can just use an ohm meter on fords or a paperclip on gms to pull the obd1 codes.
Old Jun 5, 2004 | 06:35 AM
tchamber's Avatar
tchamber
OK, mdvaldosta, like I said, I have one, and have the code.........172. I checked my O2s with a handy little multimeter, they're good to go. What else could it be? MAF checked out ok. Any more ideas?
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Dathan
Oct 5, 2015 05:52 AM
