how can i turn the ac off
without removing the belt?
no matter what position i put the damn thing on, it just blows and blows and blows.
the temp **** works. if its on hot it will blow hot and vice versa for cold.
if its hot outside it wont blow cold. it blows the engine heat inside and it makes it very hot.
weird thing is it only does it when its hot? ive never seen anything like this. all vac lines are secure and the compressor is fine. when i put it on it works good but there is just no way to turn the damn thing off. its like got a brain of its own
its possessed...lol, j/k.
But it could be a small hole in your vaccum lines under your dash, did you check all those?
They're connected to the back of your *****. Check all them, they could be f*cked up and you wouldnt even notice it.
If the pump is running then its probably something electrical. You can try removing the wires on the back of the panel for a quick fix but you'll have to break out a meter to find where the problem is.
I'll trade you problems. You could have my no a/c if you want.
I took it all out, the box under the dash, the hoses under the hood, everthing.
Dropped 32lbs to.
