Won't start when cold
Old Aug 9, 2006 | 12:04 AM
fishfamilyracing's Avatar
fishfamilyracing
Default Won't start when cold
We have an 88 Mustang 5.0 GT. The car cranked and cranked, but wouldn't fire. Gas is getting into the fuel log and power is getting to the injectors. I could take the air inlet off and spray starting fluid in the intake and it will start. The car will run from that point on. If you rev it up it wants to die, but if you let it idle until it warms up it will run just fine. Any ideas.
Old Aug 9, 2006 | 12:06 AM
jzgt's Avatar
jzgt
Default RE: Won't start when cold
Try putting the gas pedal to the floor and then starting (obviously taking it off if and when it starts).
Let me know if that does anything
- Jeff
Old Aug 9, 2006 | 12:09 AM
fishfamilyracing
Tried that, didn't work
Old Aug 9, 2006 | 12:14 AM
jzgt's Avatar
jzgt
Hmm...have you pulled any codes?
- Jeff
Old Aug 9, 2006 | 12:28 AM
fishfamilyracing
no
Old Aug 9, 2006 | 12:56 AM
jzgt's Avatar
jzgt
I'd try that as it seems your problem is when the car is in open loop. The system is not adaptive in that mode so I'd be interested if there are codes - especially since it's fine in closed loop.
- Jeff
Edit: I meant to ask - have you done anything to the car? It's still SD, right?
Old Aug 9, 2006 | 01:01 AM
Stiffclutch's Avatar
Stiffclutch
is this car carb'd this sounds like a problem i have had after some of my carb'd cars set for awhile ( the camaro sits the most too scared someone'll bump me at a light ) but if it's not i would run the codes if it is i would check the metering rods and vac lines i would also check the van lines if it is Efi also
Old Aug 9, 2006 | 01:02 AM
fishfamilyracing
no carb
Old Aug 9, 2006 | 01:04 AM
jzgt's Avatar
jzgt
is it still Speed Desnity?
- Jeff
Old Aug 9, 2006 | 01:07 AM
fishfamilyracing
car is stock, completly stock
88 gt 60,000 miles
