Need Advice!!!
Old Aug 11, 2006 | 02:49 AM
jknowles249's Avatar
jknowles249
Default Need Advice!!!
I got that RAM air kit on my car with the mass air flow conversion kit too. And today had to drive thru a big rain storm. Now my stang is blowing black smoke and choking at low speeds and not idling at all. But If I open the throttle wide open It runs good, suggesting That my computer is just dumping way too much fuel, right? Will water ruin a MAF sensor, or what do you guys think might be to blame?
Old Aug 11, 2006 | 02:51 AM
ckyguy68's Avatar
ckyguy68
Default RE: Need Advice!!!
could have just dirtied the MAF... clean the wires with carb cleaner and a q tip. unplug the neg. battery cable for 30 minutes and then back in. you should be good.
Old Aug 11, 2006 | 02:55 AM
jknowles249
I cleaned the MAF with starter fluid. But I did not unplug the battery to reset the comp. I let it sit for about 5 hours. Went and started it up and it idled fine until it got warm and then I suppoese the computer kicked in.
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Shadow7874
Sep 24, 2015 09:06 PM
2k232
Sep 16, 2015 10:28 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
