Timing Please help
I ve been putting alot of bolt ons to my 91 gt i still have the all stock internals and cam....I was wonder what i should advace my timing to ??? is it 18 degreess or what please respond thanks....mustangkid
I would set it to 14* first and see how it runs at WOT. If you don't hear any pinging, then you can advance it more if you chose. If you DO hear pinging, then set it back a bit and you should be all set. Just remember to run the higher octane gasoline. No more 87 and no cheating and going with 89. 91+ only
Oh, and don't be a dumbass like me. remember to remove the spout connector when you do it
You should be able to run 13-14 degrees with no pinging on 87 octane. I didnt have any problems but upgraded to 89 anyway just to be on the safe side. There is a tech article in the stickies. Check it out.
https://mustangforums.com/m_1531258/...tm.htm#1531258
ORIGINAL: MustangKid5.0
thanks guys that was really fast.....so will i feel a performance gain in bumping my timming or what
mungodrums
Oct 7, 2015 04:01 AM
Sep 8, 2015 11:50 AM
