Wierd Idle Problems
Ever since installing my new intake manifold, I've been having wierd idling issues. It doesn't seem to want to idle below 900 RPM's anymore, versus the 600 that it did before. Also, if I'm just in Neutral, give it a quick rev, it seems to stick at 1800 for about 3 seconds, then down to 1500 for another 3 secs, then back down to 900. The wierder thing is though, while I'm driving and I press the clutch pedal it revs up, in between shifts and while parking. All help again appreciated. Thanks
A vacuum leak is what I had thought as well. I had a friend of mine check it all out while I was working today, he sprayed and couldn't find any leaks.
Also, I guess as an update, while I was driving it tonight if I let off the throttle it wants to stay at the same speed...not deccelerate as it should.
It's almost like its on permanent Cruise Control. And again very high idling when the clutch is depressed...around 1700 RPMS...it just jumps right up.
As for now I definitely think a vacuum leak is the problem. Any other possibilities anyone? Also would it still be ok to drive under this circumstance? Thanks again all
This problem is common with my other car - Thunderbird Turbo Coupe. It required testing the throttle position sensor to see if there were any dead spots initially, then adjusting the idle (requires a DMM). I did that to the Tbird and the idle never hung again. I know its a different car/engine, but the problem sounds the exact same. Hope this helps.
Ever think it could just be your cable sticking?
ORIGINAL: Myfetang
Just unhook the negative battery cable for 15 mins??
I'd say vacum leak as well. Did you reset the computer? Give that a try.
