pulling codes
Old Aug 18, 2006 | 05:08 AM
settled4automatic's Avatar
settled4automatic
Default pulling codes
i was trying to pull codes on my 88gt this afternoon, and all i got was a solid light with my test light. i jumped everything right, and followed the directions i got from Joel on here... with key off, it was a solid dim light, key on was a solid bright light.
any thoughts??
Old Aug 18, 2006 | 10:05 AM
Joel5.0's Avatar
Joel5.0
Default RE: pulling codes
Try placing the jumper from the STI connector to a good ground instead. If you have a problem with the SIGRTN wire at the VIP connector, self-test will no be initiated. LUK the outcome.
Old Aug 18, 2006 | 11:35 AM
5speed GT's Avatar
5speed GT
does anyone have the info on how to do this? I'm trying to figure out my problem
Old Aug 18, 2006 | 02:01 PM
Joel5.0's Avatar
Joel5.0
- DIY KOEO/KOER Self-Tests and Cylinder Balance Test
and if the above link to m-y-5-o-h.com still doesn’t work, use
- How to run a KOEO, KOER Self-Test codes scan and Cylinder Balance Test, or this other one instead.
Old Aug 18, 2006 | 03:35 PM
settled4automatic
i'll try a different ground today and see what happens.
Old Aug 18, 2006 | 03:52 PM
settled4automatic
i grounded the sti input to a strut tower bolt, and got some codes!!
51, 22, 53, 54, 35, and 67. so i guess i'll go see what they mean! thanks joel
found the meanings -- i think they're mostly set because of things i unplugged with the key on/cranking/etc to check things out. i'm gonna clear them out and try again tomorrow
Old Aug 18, 2006 | 04:05 PM
settled4automatic
edit:: above ^^^^
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
