Header Install?
Old Aug 18, 2006 | 07:04 PM
Champ561's Avatar
Champ561
Default Header Install?
My friend just picked up a set of bbk shortys and we are gonna install them saturday. I didnt do the install on mine because I got them around the same time my blower was getting done. So I was wondering if there are any tricks to make the install easier?
Old Aug 18, 2006 | 07:12 PM
mustang93's Avatar
mustang93
Default RE: Header Install?
umm..........pretty basick stuff... just remember where the spark plug wires go so you dont screw up the firing order.... other than that pretty simple!
Old Aug 18, 2006 | 07:33 PM
anthonydalrymple's Avatar
anthonydalrymple
Pull the plug wires off of the plugs, after twisting the boot back & forth. Otherwise, you risk pulling the terminal end off & having more $ to spend....
Number the plug boots with a Sharpe black perminent pen, starting on the passenger side front of the motor(#1).
Pull the plugs out if you want to be really careful, lack experience, or run into problems wit the fitment. One slip & broken porcelyn may occurr....
Expect to massage the oil dipstick tube. Careful bending is all that is needed.....
Expect to remove the flimsy & most likely dry rotted plastic vacuum lines on the passenger side of the motor. Be prepared & have some 1\8" vacuum hose from the parts store ready should you "snap" one.....
That should be enough info to make you "dangerious".....
Old Aug 19, 2006 | 03:06 AM
89GTRed's Avatar
89GTRed
most likely will have to unbolt the h pipe and slide it back to get the header bolts to match up to it.
Old Aug 19, 2006 | 03:14 AM
Goosepoop302's Avatar
Goosepoop302
k i got a bolt from my headers to my heads that wants to keep going in crooked is there anything i can do to fix it??? im hthinking im gunna loctite it and super high temp rtv it to make sure it dont leak and get it in best i can ><
Old Aug 19, 2006 | 03:50 AM
89GTRed's Avatar
89GTRed
just keep trying to thread it right until it goes in strait. dont wanna crossthread that chit....[&o]
Old Aug 19, 2006 | 03:52 AM
Goosepoop302
well if its started cross threaded there aint **** i can do now is there.
Old Aug 19, 2006 | 03:54 AM
r.barn's Avatar
r.barn
you can try and chase it with a thread tapper
take the header off, and try and start the bolt with nothing in the
way. make sure threads are ok first, then try again
just be patient with it.
Old Aug 19, 2006 | 03:56 AM
Goosepoop302
whats a thread chaser look like
Old Aug 19, 2006 | 04:00 AM
89GTRed's Avatar
89GTRed
whoa dont get your panties in a bunch,[&:] I didnt know you had ALREADY crossthreaded it bro. just thought you were having probs getting it in. and yea +1 to what r.barn said.[sm=youreright.gif]
