Temperature Sending Unit - Need Advice
Old Aug 27, 2006 | 11:26 PM
YallsChris's Avatar
YallsChris
Default Temperature Sending Unit - Need Advice
Hi Guys -
Forgive me, but I am new to this.
I have a 1989 Mustang LX (5.0) and my temperature gage doesn't work.
As info, the heater core broke and is now bypassed (no hoses/tubes going into the heater core).
From reading on this forum, I believe it doesn't matter since the temeprature sending unit that provides feedback to the gage, sits on the intake manifold to the front right of the lower intake when looking at the motor from the front of the car. Is this correct?
Does anyone have a better picture of the sending unit than what I found in the Haynes book?
Also, how could I test if the temperature sending unit is broken, or the gage is faulty? I think the unit is not that expensive, but if it can be tested, that would be great. Does it have to do with the by-passed heater core?
Any help??? Please.
Thanks, Chris
Old Aug 27, 2006 | 11:30 PM
PONY GUY's Avatar
PONY GUY
Default RE: Temperature Sending Unit - Need Advice
you can test to see if the sending unit is good but you will need a multi-meter to do so you can get a decent one from sears for 30 bucks
Old Aug 28, 2006 | 12:04 AM
YallsChris's Avatar
YallsChris
Thanks, but how exactly do I measure it?
I have a multimeter, but I don't know how to measure on the unit?
Any step by step instructions?
Thanks a lot.
Old Aug 28, 2006 | 12:07 AM
PONY GUY's Avatar
PONY GUY
I belive you wanna see 5 mili amps then when you have power to it it should drop to 0 or vise versa electrical is one of my worst area's your hayes book shuld have some kinda trouble shooting in it
Old Aug 28, 2006 | 12:16 AM
5.0stanger's Avatar
5.0stanger
I think you can just take the wire off the sending unit and ground it out....the gauge should jump all the way up if it is good.
Old Aug 28, 2006 | 12:39 AM
YallsChris's Avatar
YallsChris
Nice,
my Hayes manual states to use two resistors on the cable, one to represent hot and one cold. Put into disconnected wire and ground to engine. Gauge should indicate hot engine. If indication is properly, the sending unit is bad.
My problem until now is to find that da#@ sender unit and wire. First I thought I found it, but I think I found the oil-pressure unit just above the oil filter. I used an ohm meter on that. the wire was ok, but testing the unit it didn't show anything (on the oil pressure unit). not sure what to think of that, because I see good oil temperature and don't have an extra oil pressur egauge. Any input on that one too?
Mor eimportant is the temperature test unit thoguh, because the gauge is not showing anything. I will try y'alls input tomorrow.
Thanks and please keep it coming if you have more info.
Chris
Old Aug 28, 2006 | 01:05 AM
YallsChris's Avatar
YallsChris
One more thing.
What is the difference between a coolant sensor and a temperature sending unit?
on www.yearone.com, I can find both, but one (coolant sensor) is $30.95 and the temperature sending unit (SW925) is $15.90.
Yes, the price is different and I believe the purpose is different too. Any input. Sorry
http://www.yearone.com/serverfiles/f...ender&SM=1&SC=
Take a look at it and maybe someone knows the difference. I think I am actually in need of the cheaper on in case my gauge checks out to be ok.
Chris
Old Aug 28, 2006 | 01:12 AM
PONY GUY's Avatar
PONY GUY
one is for carburated stange (sending unit) and one is for fule injected ( sensor) I think its on the intake manifold on the driver side
Old Aug 28, 2006 | 01:59 AM
YallsChris's Avatar
YallsChris
Darn, that means since I have no carb. I will need to buy the more expensive one?
I guess U just try to locate that thing and will see how mine looks.
Thanks for the input.
Old Aug 28, 2006 | 02:31 AM
Mustangkiler's Avatar
Mustangkiler
i thought the sending unit or temp switch sends the temp to ur gauge and ur coolant sensor sends it to ur computer, so u have two actually, since a 92 camaro a guy i know has two and my truck does
