Trouble code
Old Aug 30, 2006 | 06:56 PM
PJB's Avatar
PJB
Default Trouble code
I scanned my car today and it came up with trouble code 63- TPS Voltage too low or grounded.
What exactly does that mean?
It shows up with both the KOEO and KOER tests.
Old Aug 30, 2006 | 07:57 PM
50Trippin's Avatar
50Trippin
Default RE: Trouble code
TPS Adjustment
Check out this link. It can be used to check if the TPS voltage is out of range. If you cannot get proper voltage try and check voltage going into the TPS. If that voltage is ok (I believe it's a 5 volt source) then I would suspect your TPS is bad.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
CS2007
Jun 25, 2019 09:45 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Dathan
Oct 5, 2015 05:52 AM
