POWER PIPE
Old Sep 1, 2006 | 12:34 PM
HC_CrAzYHoRsE's Avatar
HC_CrAzYHoRsE
Default RE: POWER PIPE
yes they do ....and they're definetly worth it, better/faster airflow and slight increase in boost.
Old Sep 1, 2006 | 12:53 PM
88BlueGT's Avatar
88BlueGT
Im not sure if its worth it for a NA car but for a SC'd car its definetly worth it. I heard anywhere from 1-2psi.
Old Sep 1, 2006 | 01:13 PM
bouchermb's Avatar
bouchermb
Works for me and any idea what the Anderson pipe costs?
Old Sep 1, 2006 | 01:57 PM
88BlueGT's Avatar
88BlueGT
$250
Old Sep 1, 2006 | 02:14 PM
I G Joe's Avatar
I G Joe
i guess maybe if your sitting at a stand still it might make a difference but if your moving your engine compartment isnt that hot.
Old Sep 1, 2006 | 03:18 PM
luckythirteen13's Avatar
luckythirteen13
ORIGINAL: I G Joe
the engine compartment is boiling hot all the time. the engine is always letting off heat and it takes up almost all of the engine compartment. and when you have a sc, its even hotter under the hood because the sc puts off as much heat as the motor.
bouchermb, you can check UPR. theirs is made of thick ABS plastic, which doesnt absorb heat and its a little cheaper then the metal one from afm. not sure how much cheaper tho
Old Sep 1, 2006 | 07:43 PM
bouchermb's Avatar
bouchermb
So do you guys think the UPR is the way to go?
I thought Black Snake has a UPR and it's metal. I might be wrong though, but it certinly does look metal.
Old Sep 1, 2006 | 09:14 PM
Black Snake's Avatar
Black Snake
MIne is a UPR, its plastic, I just painted it.
Old Sep 1, 2006 | 09:21 PM
Sic5OohSC's Avatar
Sic5OohSC
I have a UPR, I dont know if it helps. Ive always had it!
Might not help you at all but now you know I have one
Old Sep 1, 2006 | 09:57 PM
Silver88T's Avatar
Silver88T
If you dont want to spend all the money then jus get a 3in pipe thats used for big trucks and get it bent at a local muffler shop thats what i did
ak98
Feb 18, 2023 08:36 AM
trashxtrash
Sep 20, 2015 10:49 PM
BrantleyS550
Sep 14, 2015 04:18 PM
jaiidutch
Sep 14, 2015 10:29 AM
wawagner82
Sep 13, 2015 09:02 AM
