bbk afpr
Old Sep 3, 2006 | 02:46 AM
Mustangkiler's Avatar
Mustangkiler
Default bbk afpr
i got a bbk afpr, no matter how i adjust it, fuel pressure stays the same, is it junk? i only have stock injectors and yes i am adjusting it correctly
Old Sep 3, 2006 | 02:49 AM
Black Snake's Avatar
Black Snake
Default RE: bbk afpr
Prolly dont have the pump to support highe FP
When you adjusting th FP, is the vacum connected?
Old Sep 3, 2006 | 02:50 AM
Mustangkiler
no its not connected and i just installed a 255 fuel pump
Old Sep 3, 2006 | 02:52 AM
grabbem88's Avatar
grabbem88
it's just a plunger,and diaphram....
Old Sep 3, 2006 | 02:53 AM
Black Snake
whats it at right now? And what gauge you using?
Old Sep 3, 2006 | 02:54 AM
Mustangkiler
ok.... but would you say its junk, because no matter how i adjust it, it wont increase or decrease and whe ni first start the car it wants to die out at first.
Old Sep 3, 2006 | 02:55 AM
Mustangkiler
its at just below 40 with the vaccum hose detached, and it should be at 40 and im using an actron gauge at the schrader valve
Old Sep 3, 2006 | 02:56 AM
grabbem88's Avatar
grabbem88
no leaks i presume?...tap on it..
Mustangkiler
i looked all around it, dont see any at all
Old Sep 3, 2006 | 02:58 AM
grabbem88's Avatar
grabbem88
sounds like needle isn't seated or bottemed out.
