Compression Ratio
I have a quickie question, i have srp flat tops 10:1 CRs, i know that 10:1 is not ideal for adding a s/c or turbo. Is there anyway to lower the compression without new pistons?
-engine is a 347 stroker, let me know what other info would help.
I'm not totally sure but I think your out of luck.
I think you should go naturally aspirated and make a powerhouse of a car.
[IMG]local://upfiles/47931/06DAF376859D428A90EFBEF06C9998CF.jpg[/IMG]
yea i thought i was out of luck, i order my heads afr 165s so i know ill gain alot from that. im running thumper e7s and compared to my dads 347 in his 88 mine is a joke. Thats why i was thinking boost, honestly the stroker is cracking out the power i was expecting i know the heads are killing it but well hell heres the build
Trickflow street head upper and lower
24lb inj.
75mm maf cal'd for the 24s
BBK 75mm TB
bored 30 over
SRP Pistons-Flat tops
Eagle Forged Crank
Crane Custom grind
1.7 crane gold rockers
i have all the supporting stuff also like 3.73s, ram power grip clutch(an amazing add on glad i chose this clutch), light weight flywheel, Tremec tranny, full suspension with sub frames.
24lb inj.
BBK 75mm TB
bored 30 over
Eagle Forged Crank
Crane Custom grind
well i ordered afr 165s so i guess im gonna have to find teh $$ and jus do my pistons and do this the right way lol. I don't want to but i guess its what needs to be done. Ill end up selling the srp flat tops so ill get some money back out of it all.
Get some stuff milled of the top of the piston. I'll bet you could take of .060.
Not the best way to do but that would lower CR. Then use 70cc heads, thick gaskets and be easy on boost.
Another way way to do is to send me the pistons and then order a set that's what you need........
