mass air sensor
Old Sep 6, 2006 | 03:37 PM
f150 cobra's Avatar
f150 cobra
Default mass air sensor
does it matter how big the m/a sensor is compared to the throttle body like if use a 75mm throttle body and a 90mm m/a sensor would it cause any trouble
Old Sep 6, 2006 | 03:39 PM
5speed GT's Avatar
5speed GT
Default RE: mass air sensor
I might be corrected, but i dont see where it would make any difference
88mustang's Avatar
88mustang
The mass air should always be bigger than the tb, so they would work fine together. But neither one should be used on a stock setup. Whats are the other mods?
Old Sep 6, 2006 | 03:47 PM
f150 cobra's Avatar
f150 cobra
331 stroker, holly systemax II intake, 185cc afr heads, 30# injectors
7upedition's Avatar
7upedition
well the rule of thumb is that the MAF should be equal to or larger than the TB, generally speaking the TB should be the same size as the inlet on the upper intake otherwise a lip will be created , interfering with airflow. what intake/ motor setup are you running? a 90 MAF will be okay with a 75mm TB but the sensor needs to be cal'd to the injector size your running. give more info on what your setup is and what your trying to do...k
Old Sep 6, 2006 | 03:48 PM
7upedition's Avatar
7upedition
i must type slow....
Old Sep 6, 2006 | 03:50 PM
f150 cobra's Avatar
f150 cobra
do you guys think this could accomplish 400hp?
Old Sep 6, 2006 | 03:51 PM
88mustang's Avatar
88mustang
80mm would probly be big enough
Old Sep 6, 2006 | 04:54 PM
primetime5.0's Avatar
primetime5.0
what cam are you using? what compression? it should make about 400
Old Sep 6, 2006 | 06:55 PM
7upedition's Avatar
7upedition
i'd say with a 9:1 or 10:1 compression, 345 hp
