fuel pump
Its one of those things you can figure out when you look at it. You just drop the tank out, unhook the neck from the side of the tank, its on top of the tank down inside of it. You should be able to figure it out when you get under there.
^and thats pretty much it. i had to do this at the beginning of the year, and that was the first time i've done a fuel pump. it wasn't as complicated as i thought. if worse comes to worse though order a haynes book. your local automotive shop or your pep boys or auto zone could probably order you one. they go for about $22 bucks, and some odd change. i have one for all three of my vehicles, and i use it everytime i gotta make a repair. very informative step by step detail. works for me, and i aint been to a mechanic in over 18 years[psshh almost as long as i been driving!] good luck.
ORIGINAL: 88stang5.0GT
well dont i have to get the fuel pressure down? and i have a chiltons but it kinda sucks anytime ive done anything ive just winged it and it turned out good
well this is my 2nd 5.0 so ive done 3 alt., 1 smog pump, new radiator(broke the tranny cooler line had to fix it with brake tubing and compression fittings), heater core tubes, thermostat, and easy stuff like plug wires, oil changes, new coolant hoses
yeah similar to what happened to mine. if you can do a radiator the fuel pump shouldn't be so tough. i'd say out of everything i've ever done with cars the radiator was the 2nd biggest pain to do[1st being replacing a transmission]. i gotta give you credit though for working on the things yourself. a lot of people will throw their cars into the shop, and what not. after a bad experience[my first car 73 mach 1 being in the shop for 3 weeks after i bought it for a tune up, and some tires,] i've never been to a mechanic again.
