differential is leaking
Old Sep 7, 2006 | 11:38 PM
93 LX FiveO's Avatar
93 LX FiveO
Default differential is leaking
when i first got my car the rearend had no stains.. looking at it today i could see the bottom was wet. common thing on most mustangs.
looking at getting a mr.gasket cover and seal what do u guys think?
http://store.summitracing.com/partde...5&autoview=sku
what kind of fluid should i get? my friend at work is gunna do the work for free
Old Sep 7, 2006 | 11:41 PM
gizim_1132's Avatar
gizim_1132
Default RE: differential is leaking
Looks cool man I'd do it seems like a pretty cool friend you got there I would run some thick fluid whatever you do.
Old Sep 7, 2006 | 11:45 PM
93 LX FiveO
do i just use a gear/tranmission oil?
how many quarts? im also goin to put in a friction modifier
Old Sep 7, 2006 | 11:52 PM
gizim_1132's Avatar
gizim_1132
Yea just use gear oil there is a plug around the top of the housing somewhere you just fill it all the way up till it leaks out of that hole.
Old Sep 7, 2006 | 11:53 PM
hardcore91LX's Avatar
hardcore91LX
I would go with what ever fluid you want but while your at it I would install this cover instead.
Old Sep 8, 2006 | 12:10 AM
93 LX FiveO
dont have $130 for a cover.. id say $35 for a chrome cover and gasket is worth the money although that trickflow cover is nice.. i just dont see the need for it
Old Sep 8, 2006 | 12:29 AM
hardcore91LX
Actually the trick flow cover does serve a purpose that the crome one wont. It puts pressure on the bearings so the dont distort under load.
Old Sep 8, 2006 | 12:32 AM
nmerrill's Avatar
nmerrill
Get this one so you can check out what is going on inside, i really want one for my truck
Old Sep 8, 2006 | 12:53 AM
silver91gt's Avatar
silver91gt
you should use 80w90 gear oil, they call it gear oil for a reason.
make sure you add at least 1 bottle of limited slip additive, ford is the best one.
the rear takes around 3 litres of oil.
the covers with bearing supports help for high horsepower applications, and make it easier to fill/drain, because they come with fill and drain plugs built in.
I have a T&A performance girdle cover and it is the same as the trickflow, and all the other covers like that.
there is no point to getting a chrome cover, unless your car is a showcar.
if the oil is coming from where the driveshaft bolts on it will be a little more involved than just changing the cover gasket.
Old Sep 9, 2006 | 11:44 AM
93 LX FiveO
it does leak where the driveshaft meets
whats the real problem then?
