Loping Idle
Old Mar 7, 2003 | 01:21 PM
kornfan_88's Avatar
kornfan_88
Default Loping Idle
My car idles from about 400 rpm to 1000rpm and just keeps rising and falling between those ranges. It will idle fine for about a minute or so and then starts doing it. It also almost cuts off after I start it when it has been started after it has been run. Any ideas? I was thinking maybe Idle/Air Control. THanks.
Patrick
Old Mar 7, 2003 | 04:22 PM
spike306's Avatar
spike306
Default Loping Idle
what mods do you have on your stang kornfan?
Old Mar 7, 2003 | 07:21 PM
lloydchristmas's Avatar
lloydchristmas
Default Loping Idle
I would check the IAC first. unplug it and see what happens
Old Mar 7, 2003 | 09:18 PM
kornfan_88's Avatar
kornfan_88
Default Loping Idle
The car is completely stock.
Old Mar 8, 2003 | 03:25 PM
spike306's Avatar
spike306
Default Loping Idle
i had that same problem in an 88 gt. we simply just cleaned out the throttle body were the butterfly is. sometimes you will find a lot of build up there. also don't forget the tubing in the cold air kit
Old Mar 8, 2003 | 07:44 PM
91GT5.0's Avatar
91GT5.0
Default Loping Idle
Sounds like a vacuum leak. Check all the lines going into the intake, the FP Reg., line running from the smog pump, etc. . .
Old Mar 8, 2003 | 08:59 PM
lloydchristmas
Default Loping Idle
if nothing changes when you unplug the iac, spray carb cleaner on the vaccum lines one at a time and see if the idle surges
Old Aug 10, 2003 | 06:06 PM
stalker92's Avatar
stalker92
Default Loping Idle
MY idle sticks at about 1500 for a second then drops to 1000 for a for a couple seconds then drops to normal, and i cant seem to find the problem,I heard to do something with an oimes meter have any ideas?
Old Aug 11, 2003 | 12:51 AM
vfast's Avatar
vfast
I ♥ Acer
Default Loping Idle
it's most likely in the dist....
Old Oct 18, 2006 | 09:47 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Default RE: Loping Idle
ive seen a few things to cause this. first is the IAC, then the throttle position sensor, or maybe the map sensor. then you have vaccum leaks and so on.
