Vibration at Idle
Old Sep 12, 2006 | 04:05 PM
Uncle Jack's Avatar
Uncle Jack
Default Vibration at Idle
95 GT W/auto trans... There is a loud vibration when at idle that seems to come from the transmission area. Almost sounds like the transmission filter is vibrating against the bottom pan. It's a very tinny sound. This has been going on for a long time but seems to be getting worse lately. I'm afraid to bring into a Transmission shop for fear they want to rebuild. BTW this is the 3rd transmission (and best yet) on this car, all by Ford.
Thanks.
Old Sep 12, 2006 | 04:06 PM
grabbem88's Avatar
grabbem88
Default RE: Vibration at Idle
sounds l;ike a pilot bearing or throw out bearing.
Old Sep 12, 2006 | 04:17 PM
jettin169's Avatar
jettin169
There isn't a throw out bearing on an Automatic tranny. I'd check your tranny mount. Could be your flywheel too.... but the only way to check that is to drop the tranny.
Old Sep 12, 2006 | 06:03 PM
TMeyer29's Avatar
TMeyer29
i know its not really by the tranny...but look over your harmonic balancer.I just replaced mine.It did the same thing
Old Sep 12, 2006 | 08:26 PM
Uncle Jack's Avatar
Uncle Jack
Thanks, I had the harmonic balancer replaced just recently. That was definitely noticeable. I should add this vibration now is more noise then actually felt.
Old Sep 12, 2006 | 08:45 PM
TMeyer29's Avatar
TMeyer29
may be the flywheel is damaged..im not sure
Old Sep 12, 2006 | 09:46 PM
will's Avatar
will
Check your torque converter/starter sheilds between engine and trans
Old Sep 13, 2006 | 08:56 AM
grabbem88's Avatar
grabbem88
well i over looked the auto tranny.....no flywheel either einstien.
ORIGINAL: jettin169
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
MacSerio
Sep 27, 2015 01:05 PM
