Anyone else???
Old Sep 16, 2006 | 01:21 AM
92hatchLX's Avatar
92hatchLX
Default Anyone else???
Have Trick Flow upper and lower intake manifolds and tried to fit a Kirban adj. FPR next to it and it won't fit??? Or am I the only one?
Old Sep 16, 2006 | 01:29 AM
XSRACINGGT's Avatar
XSRACINGGT
Default RE: Anyone else???
i got a tfs street heat and my kirban fits perfectly. little tight tho. kinda like those back upper intake nuts. hehe. those are a beeeyoootch! hehe[sm=WTFsgign.gif]
Old Sep 16, 2006 | 01:30 AM
92hatchLX's Avatar
92hatchLX
Yeah they are! Should I try to go and put that bitch on right now?
Old Sep 16, 2006 | 01:41 AM
XSRACINGGT's Avatar
XSRACINGGT
yeah. the screws that attach the regulator are kinda hard to get started when you put the new one on. I would suggest at least taking the upper intake loose so you have more room. just kinda slide it out of the way towards the drivers side. then you can reach the fuel rail easier. they are allen heads. i got mine off with the shirt end of the allen in the screw. I had enough room to do that. I think it took me around 30 min or so. but I have had my intake off alot, so its pretty dang easy by now for me. hehe.
Old Sep 16, 2006 | 11:15 AM
92hatchLX's Avatar
92hatchLX
Yeah, I had it on there before, but when I went to put the upper back on it wouldn't fit, oh well, maybe this weekend I'll make it fit.
Old Sep 16, 2006 | 11:30 AM
grabbem88's Avatar
grabbem88
i think i just loosened the fuel rail,and swapped my kirban for my areomotive..yes i do have a 1 in spacer,but you should still be able to install it.
Old Apr 29, 2007 | 01:37 AM
cheetha94607's Avatar
cheetha94607
i'm having the same problem think i might need to make a spacer for my egr plate or just get a 1to 2 inch intake spacer. please let me know if you installed your fpr.
Old Apr 30, 2007 | 12:03 AM
cheetha94607
currently had the same problem but got mine to work by bending the line and tightening the nuts for my throttlebody
