Won't Start, backfires
Old Oct 2, 2006 | 08:57 AM
RacquetballRyan's Avatar
RacquetballRyan
Default Won't Start, backfires
Alright, it wont turn over but every 100th or so time, and when it does start up if you take it about say...2700 rpms it backfires really bad...anyone know why this is?
Old Oct 2, 2006 | 09:36 AM
Sacmo's Avatar
Sacmo
Default RE: Won't Start, backfires
Have you done any recent work on it??? kind of sounds like your timing is off or a couple swapped plug wires...
Old Oct 2, 2006 | 12:12 PM
grabbem88's Avatar
grabbem88
+1
Old Oct 2, 2006 | 12:30 PM
BlackMustang02GT's Avatar
BlackMustang02GT
your firing order may be all fuc|<ed up. 1,3,7,2,6,5,4,8
Old Oct 2, 2006 | 12:36 PM
88stangaruu's Avatar
88stangaruu
Check the timing. Sounds like to much timing.
Old Oct 2, 2006 | 12:43 PM
grabbem88's Avatar
grabbem88
too much timing will cause hard starts...mostly from the heat....
i wish people were online when help comes
Old Oct 2, 2006 | 05:07 PM
RacquetballRyan
I just got new wires, so that might be it.
I'm going to go check the firing order. Which one do I start with?
grabbem88's Avatar
grabbem88
number one then go around
Old Oct 2, 2006 | 05:08 PM
RacquetballRyan
Alright, is the timing easy to change?
If so, how do I do it, and what do I set it to?
Old Oct 2, 2006 | 05:12 PM
grabbem88's Avatar
grabbem88
got a timing light?...ground/pos #1 plug pull spouter point check if wrong...shut car off loosen hold down bolt start engine check and adjust to desired timing< stay with 10* till you know for sure what your problem is...shut car off tighten bolt plug spouter in restart and recheck timing.
