Whats the ideal throttle body
Old Oct 2, 2006 | 10:42 PM
LX 5.0's Avatar
LX 5.0
Default Whats the ideal throttle body
I was going to get a 65 or 70 bbk. What you guys recommend?
Old Oct 2, 2006 | 10:44 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Whats the ideal throttle body
accufab if you can afford it.
Old Oct 2, 2006 | 10:46 PM
92hatchLX's Avatar
92hatchLX
70mm! Perfect size for a stock, bolt on, H/C/I, or some type forced induction.
Old Oct 2, 2006 | 10:48 PM
Stevens91gt's Avatar
Stevens91gt
i say 70mm..that's what i have..dont go bigger though
Old Oct 2, 2006 | 10:53 PM
LX 5.0's Avatar
LX 5.0
Are there any negative aspects of such a throttle body
Old Oct 2, 2006 | 11:01 PM
92hatchLX's Avatar
92hatchLX
umm none, but there are quite a bit of positive ones!
Old Oct 2, 2006 | 11:29 PM
ZachW04Stang's Avatar
ZachW04Stang
Whats a 70 mm throttle body going to do if you don't even have an intake opening that big? A 65mm tb can handle 550hp at the wheels no problem. I've seen it done. I think a 65mm is about as big as I'd go unless your going for forced induction.
Old Oct 3, 2006 | 12:19 AM
Foxy5.0's Avatar
Foxy5.0
Just make sure that your MAF is larger in diameter that your' TB. You want air flow to funnel into your engine. I have the stock filter box minus the silencer of course. I use the stock intake tubing because it has better resistance to engine heat than the super heat absorbent aluminum tubes. I use CnL's 73mm MAF housing. I like CnL because it uses the stock MAF sensor but fools it with a calibrated air tube. The stock MAF sensor is more accurate than most aftermarket. Then I purchased BBK's 70mm TB off e-Bay and printed the installation/calibration instructions of summit racings website. I needed to hone out the stock rubber elbow to fit over the TB. I had my stock EGR plate honed and matched to the TB. I also had the stock upper intake manifold honed and matched to the EGR plate. I was going to gasket match the rest of the manifold and match it to the heads. But it is my daily driven car and only had a weekend to get it done.
Old Oct 3, 2006 | 12:55 AM
91RedGT's Avatar
91RedGT
any hp gains from bigger tb and maf?
Old Oct 3, 2006 | 01:46 AM
91RedGT's Avatar
91RedGT
ORIGINAL: 91RedGT
