Headers
Old Oct 3, 2006 | 07:46 PM
MustangMadness7's Avatar
MustangMadness7
Default Headers
OK, so im curious, what is the difference in price/performance/PITA to install between LT's, Shorty equal length, and regular shorty's?
Old Oct 3, 2006 | 07:50 PM
gspfunk's Avatar
gspfunk
Default RE: Headers
This is my opinion, so others will see differently, but:
If you want easier, go w/ unequal shorties. Good hp gains, still have plug clearance, etc. If you want all the hp you can get out of an exhaust upgrade, go long tubes. They will be more problematic if you have to pull your tranny, engine, etc. Equal length shorties are not worth the hassle. You'll hate changing plugs, the gains aren't much more than unequal shorties, and for the hassle, you may as well get longtubes.
Old Oct 3, 2006 | 07:55 PM
MustangMadness7
Default RE: Headers
Is there very much of a difference in HP between the Unequal and the LT's?
Old Oct 3, 2006 | 08:22 PM
89gtsleeper's Avatar
89gtsleeper
Default RE: Headers
Yes there is gonig to be a difference.... the peak numbers may not be too far away from each other, but when you look at it across the entire rpm rang, you'll see typically the long tubes do alot better overall (which is what matters)
Old Oct 3, 2006 | 08:50 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
Default RE: Headers
go with just the unequal lengths.....a mild engine won't see any REAL benifit maybe 1-2 hp at the top end and what is most of your driving?..low to mid range
Old Oct 3, 2006 | 08:58 PM
FordMustangXBA's Avatar
FordMustangXBA
Default RE: Headers
Long tubes will cost you a little back-pressure on an engine that's not very built...If you're mostly stock unequal shorties will be just fine. Longtubes sound a little better, also. Remember they're also illegal in some states.
Old Oct 3, 2006 | 09:00 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
Default RE: Headers
let me give him this fact I run a set of equal length of my 306 s/c and make over 500 at the wheel
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Roxon68
Mar 17, 2016 08:13 PM
junior04
Sep 28, 2015 10:53 AM
trashxtrash
Sep 20, 2015 10:49 PM
BrantleyS550
Sep 14, 2015 04:18 PM
