dumb question
Old Oct 10, 2006 | 01:41 PM
93must's Avatar
93must
Default RE: dumb question
Look in your book for your car it will tell you what fuse is for what. If I was at home I would look at mine and tell you.
Old Oct 10, 2006 | 02:04 PM
88BlueGT's Avatar
88BlueGT
I would just check your bulbs first before you go crazy trying to figure it out. It prob just needs two $1 autozone bulbs.
Old Oct 10, 2006 | 02:12 PM
00limited7's Avatar
00limited7
Ok I'm assuming it's a T5. I just replaced my T5 2 weeks ago and I seen where the sensor screws into the tranny. It is on the top off the tranny on the other side away from the speedo gear. It screws in and has two wires coming out of it. If you would unscrew it you would see a ball bearing type thing on the end of it. This ball bearing pushes in to activate the reverse lights. You might jack up your car and see if those wires got damaged somehow. I don't know if you can unscrew it while the tranny is in the car or not. I have a T5 in my garage that I can take a picture of when I get home from work if you need it.
Good Luck and be safe when crawling under you ride, Jackstands!!!!
Old Oct 10, 2006 | 02:25 PM
ttoppedaerocoupe's Avatar
ttoppedaerocoupe
OOLimited is right. there is a reverse switch on the tranny itself. Im willing to be either one of the connection points broke, wires chafed, something.
alex
Old Oct 10, 2006 | 02:27 PM
ltrayne84's Avatar
ltrayne84
well its a tremek tko 600 series
Old Oct 10, 2006 | 02:57 PM
7upedition's Avatar
7upedition
call them and ask them if its in the same locaton... most likely it is
Old Oct 10, 2006 | 04:54 PM
ltrayne84's Avatar
ltrayne84
ok, thanks guys
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
