Engine code help
Old Oct 12, 2006 | 07:41 PM
Red FIVE O's Avatar
Red FIVE O
Default Engine code help
hello evryone. i was running codes today and i pulled #85 KOEO
fordfuelinjection says that it is a canister purge solenoid circuit failure.
what exactly is that? any help is appreciated.
Old Oct 12, 2006 | 07:56 PM
Red FIVE O's Avatar
Red FIVE O
Default RE: Engine code help
i also did a KOER and pulled
#21 - ECT out of test range(0.3-3.7 volts) WIch means Electronic Code Test
but it still pulled @94 & #44
Thermactor air injection system inoperative (LEft and Right side respectivly)
can some one tell me if the thermactor is a problem or not and if the #21 code means the #'s 94 &44 are false
Old Oct 12, 2006 | 08:58 PM
Red FIVE O's Avatar
Red FIVE O
Bump
Old Oct 12, 2006 | 11:30 PM
Red FIVE O's Avatar
Red FIVE O
I guess nobody knows?[sm=smiley25.gif]
Old Oct 13, 2006 | 02:17 AM
Red FIVE O's Avatar
Red FIVE O
ok after some forced research iv come across info saying that the thermactor stuff is jast a fancy name for the smog pump. well mine is disconected so thats why. and i still dont know where the canister purge is ....... jump in at any time.
Old Oct 13, 2006 | 05:03 AM
Stanger90's Avatar
Stanger90
Just a guess but wouldn't it be the soleniod on top of the charcoal canister?
Old Oct 13, 2006 | 10:33 AM
Joel5.0's Avatar
Joel5.0
The canister purge solenoid (CANP) is something like.......
ECT = Engine Coolant Temperature sensor...a code 21 gets logged if you run the KOER self-test if the engine temp is below 180° when the test is run. To confirm it is a "false" code, make sure the engine is above that temp and rerun the KOER.
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
zachary1988
Sep 4, 2015 03:04 PM
