is there a big difference between 65mm TB AND 70MM TB
i have my car at the tuning shop and he said i should of put a 65mm tb instead of a 70mm . he also said the 70mm is harder to tune the car with and i have all these things done to the are and the car has been at the shop for a week . is it that are to tune a 94 model. he is burning a chip for me . the chip is a superchip .
i bought a 302 bored over.040 to a 308 9.8:1 it has :
all forged interenals piston, i beams, rods.
- heads specs -
trick flow twisted wedged heads #51400002
61 cc combustion chamber
2.02 intake valve
1.60 exhaust valve
high rate valve spring 7,degrees lock manganese broze guides.
trick flow 1.6 roller rockers
--cam specs --
brand new trick flow track heat cam # 51402000
lift : 499 in intake / .510 in exhaust
duration : 275 intake / 2.79 exhaust
lobe separation : 112 degress
--add on to the engine--
cobra upper and lower intake manifold
bbk long tube headers
70mm throttle body edelbrock
75mm mass air pro-m
30lb injectors calibratred
255 fuel pump
bbk fuel pressure regualtor
i cant get it running right it has bad idle the air /fuel mixture is off and it dies out when coming to a stop .
- heads specs -
2.02 intake valve
1.60 exhaust valve
--cam specs --
75mm mass air pro-m
255 fuel pump
RE: is there a big difference between 65mm TB AND 70MM TB
your TB should be the same size as the inlet to your intake manifold in theory otherwise you create resistance, as far as tunign goes i have no idea... sorry
Sounds like your tuner doesnt know what hes doing and hes taking it out on a 75mm throttle body. I MIGHT of believed he knew what he was talking about if he said the 30lb injectors were a little big. If hes programming the chip that combo sounds ok although i dont see why you would need a chip with that combo.
the car has a rough idle and it is running to lean the header and cats get red after awhile at opert temp. i dont know what is going on with the car .
There is no way that with your set up that engine should be running lean naturally aspirated. You have 30lb injectors on a 308 for god sakes and a 255lph fuel pump with afp regulator. Your tuner should know to check fuel presuure and air fuel ratios when tuning a car properly. Make sure your timing is ok, and check those other 2 things i mentioned.
