Need help building motor
Old Oct 17, 2006 | 05:38 PM
homie3186's Avatar
homie3186
Default Need help building motor
I just got a 1995 5.0 now im ripping out the motor and doing a full rebuild this will be my first rebuild but I have a degree in automotive, but need help making a setup. I and goin to go with the 331 stroker kit everyone says 347 but I think im stuck on 331. So far thats all i got i want to look at 350-400 hp along with tourque i would like to have a power band from 2000-6000 if thats possible. So i dont no what i should so with upper and lower intake, heads( im not gonna build the heads gonne buy them complete), and cam. anything ones ideas would nice. if im missing anythin let me know
Old Oct 17, 2006 | 05:46 PM
only90s's Avatar
only90s
Default RE: Need help building motor
I have been doing alot of research on this topic as I was going back and forth between a 306 and a 331, but since I am supercharging I am going with the 306
2 choices...
Trick Flow Top end kit comes with:
Trick Flow’s Twisted Wedge cylinder heads (TFS-51400004), the kits include a specially matched hydraulic roller cam (TFS-51402000), roller rockers (TFS-51400510), gasket kit (TFS-51400904), timing chain, pushrods (TFS-21406700), and short valve covers. Lifters not included.
or for even more power...go with the AFR 185cc heads, Holley Systemax Intake, a Stage 2 Trick Flow Cam, or a Comp Cam Stroker Cam even better..roller rockers etc...
Whichever way you go you are going to need a bigger Throttle Body, Injectors..Mass Air possibly a fuel pump..new tune, better exhaust..etc etc....
Old Oct 17, 2006 | 11:37 PM
homie3186's Avatar
homie3186
thansk any other ideas
Old Oct 18, 2006 | 12:21 AM
nmerrill's Avatar
nmerrill
i would go with the 331, you could go with a trickflow kit, or piece it together. Piecing it together will cost a little more, but you get to customize your setup to what you like. Get some good heads, and possibly a custom grind cam. some good intakes, i like the track heat but there are tons out there, roller rockers ect..... Mainly just figure out what you want to do with the motor(NA, nitrous, FA) and go from there
firehorse02
Nov 16, 2015 11:28 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
logan409
Sep 26, 2015 07:43 PM
