need some help
Old Oct 18, 2006 | 12:47 AM
georgiaguy246's Avatar
georgiaguy246
Default need some help
i don't know much about body work but i was just wondering about this. how can you fix this? is it hard? whats it called? etc...i am talking about the thing on the drivers door, not sure what its called. any help is apprechiated, thanks guys!
Old Oct 18, 2006 | 04:02 AM
Ninety5five0's Avatar
Ninety5five0
Default RE: need some help
Its just molding. I'm pretty sure it just sticks on there, but i wouldnt ahve the slightest clue of where to get it other than the junk yard. Sorry.
Old Oct 18, 2006 | 12:00 PM
89gtsleeper's Avatar
89gtsleeper
Ask around on mustang forums... A rally common thing for fox owners to do is change out betwen lx and GT. they use different moldings. So try to find someone that5 converted a GT to an LX. Or again, look in the junkyard. It doesn't even have any screws or anything... it just uses a special putty and adheres directly to the door. If you have to pull one yourself, it will be easier if you get it hot first, then run a putty knife behhind it and gently pull. The entire thing should come right off. Before you install it on your car, I would make sure that your door is hung right, and that your hinges aren't worn out. IF the furthest rear portion of the door sags a little bit this is likely the case. you can tell by opening the door, putting your hand under it at the very rear of the door and lifting up and down. IF the door has movement those pieces are worn. Fix those first, (around 20 bucks), then once your door is very straight, install the molding so it fits evenly with the molding an the fnder and rear-quarter. Good luck.
Old Oct 18, 2006 | 12:09 PM
88BlueGT's Avatar
88BlueGT
You can get the molding from almost any mustang resoration site/company. To take a molding OFF, I used a blowdryer to heat it up and cut it off with a putty knife. Its just double sidded sticky tape... really good sticky tape lol Thats all you need to put it back on too. Theres nothing special to it at all, no screws, brackets, etc. Just double sided tape. There is a recommended tape to use but I forgot the exact name... but anyway, no it will not be hard to replace.
Old Oct 18, 2006 | 12:53 PM
Archion's Avatar
Archion
The best tape to use is the 3M trim adhesive tape, it comes in various widths, I think you would use two 3/4" strips on that piece but its been a while. I would also be worried about those flat tires...
Old Oct 18, 2006 | 01:00 PM
4fit?'s Avatar
4fit?
www.50resto.com
