!!! TECH ARTICLES !!!
https://mustangforums.com/forum/5-0l-1979-1995-mustang/195722-tech-articles.html)
HC_CrAzYHoRsE |
10-21-2006 10:17 AM |
horsepower - quarter mile calculators
Running Rich? By Mattdel
the junkyard performance thread
Mass Air Flow Conversion, From Black Snake and Schwindty
Fox body 5 lug conversion, by Stangpower96
Engine Map(Location of Parts), by Bobby
first mods (getting started), link provided by mustang4eva
TPS Adjustment, from 50Trippin
5.0 Injection Size / Color, by Sidewayz6.0
Speedometer Recalibration Gear
speedometer gear swap DIY, provided by gspfunk
94/95 V8 swap with 5 speed transmission, by Low_5.0
calibration chart for C&L meters, provided by vfart
battery relocation made easy, by Quik
head porting, links provided by fats429
how to clean your injectors, link provided by 1990mustanggt
autobody101, link provided by 91lxstang
calcualting proper size injectors, by gspfunk
interchangeable fox body parts list, courtesy of creepshow
billet quadrant, firewall adjuster and adjustable cable installation, by gspfunk
tons of info on lifters and valve springs, courtesy of Grimace5.0
Wheel Spacing Chart
adjust your timing, with help by 88BlueGT
3g alternator install, by gspfunk
info on speed density, by Twister
tunning EFI, thanks to 88BlueGT
5.0 HO Cam Specs & Speed Density Compatable Cams- by 86 5.0L
info on the 93 cobra and cobra R models, by 88blueGT & AdderMK2
Torque Box Reinforcements by PRO50SC
how to indetinfy a 302 mexican block, by Fosters82GT
How to: properly stab your distributor by AdderMK2
The End all to Weight Reduction Thread By Jasperstang308
Front spring install by 302f150
Gauge cluster removal by Wildsurfer92
Ford Tq Specs, by Madman@the wheel
Short throw shifter install by Wildsurfer92
Head valve info by jthorn9
How to repair your convertible's rear windows by Wynn
How to: upgrade your 87-93 Mustang with new shift boots by RedlineGoods.com
How to disassemble your distributor by Addermk2
Turbo Coupe Rear End Swap by mustangGT86 05
Carb To EFI Conversion by projectresto83
