Help!!!!!!!!!!!!!!!!!!!!!
Old Oct 23, 2006 | 12:08 PM
Bigdogbowl's Avatar
Bigdogbowl
Default Help!!!!!!!!!!!!!!!!!!!!!
I am getting a KOER codes of
311 AIR system inoperative during KOER (Bank number 1 with dual heated oxygen sensors)
314 AIR system inoperative during KOER (Bank number 2 wigh dual heated oxygen sensors)
I have changed out my O2 sensors about 5 months ago. I believe the EGR valve could possibly be causing this. What other problems could there be.
My engine is stock. 94 GT 5.0
Old Oct 23, 2006 | 12:14 PM
5.0stanger's Avatar
5.0stanger
Default RE: Help!!!!!!!!!!!!!!!!!!!!!
Not sure, but it may have to do with your air pump stuff...you still have you smog pump?
Old Oct 23, 2006 | 12:27 PM
Bigdogbowl's Avatar
Bigdogbowl
Is my smog pump the EGR valve?
Old Oct 23, 2006 | 12:31 PM
5.0stanger's Avatar
5.0stanger
311 Secondary air injection system inoperative during KOER self-test (bank #1).
>Those are your codes
314 Secondary air injection system inoperative during KOER self-test (bank #2)
No, your smog pump isn't your EGR.
Old Oct 23, 2006 | 12:53 PM
Bigdogbowl's Avatar
Bigdogbowl
Yes those are my codes. I'm not familiar with the smog pump.
Old Oct 23, 2006 | 04:54 PM
Twisted's Avatar
Twisted
Both of these codes are related to your smog system...not your EGR. Your Chilton's manual should describe a test for each component in the smog system to help pinpoint the problem. I did mine like a year ago. It's pretty easy. First, you make sure that the pump is putting out air, then you check your diverter and bypass valves, then your check valves...or something like that. It should be an easy fix. Good luck.
Old Oct 23, 2006 | 04:57 PM
Twisted's Avatar
Twisted
By the way...and this may save you some headaches...if all of these components check out, you may want to verify that the smog tube that runs from the back of one head to the back of the other isn't clogged. Mine was, and was putting out codes even though the rest the system was functioning.
