WILL THESE VALVESPRINGS WORK? PLEASE HELP
Old Oct 25, 2006 | 01:10 AM
flyinghigh2k8's Avatar
flyinghigh2k8
Default WILL THESE VALVESPRINGS WORK? PLEASE HELP
will the valvesprings work http://store.summitracing.com/partde...5&autoview=sku
with this cam http://store.summitracing.com/partde...0&autoview=sku
I REALLY NEED TO KNOW ASAP THANKS
Old Oct 25, 2006 | 07:17 AM
Stanpower's Avatar
Stanpower
Default RE: WILL THESE VALVESPRINGS WORK? PLEASE HELP
These will work for half that price with lots more to offer you.Check them out i'll sell them cheap.
This is a set of valves, and springs that came out of a 1989 Small block ford. The E7TE cylinder heads were rebuilt a few years ago, so the valves and springs are like new, very low miles. This comes with, 8 intake valves, 8 exhaust valves, 8 intake valve springs, 8 exhaust valve springs, and 16 valve spring retainers and keepers. I also have thrown in 16 stem seals, that are new still in original bag.FREE SHIPPING!! $40 let me know..........
[IMG]local://upfiles/48921/CABD420381284E208057415234340F72.jpg[/IMG]
Old Oct 25, 2006 | 07:22 AM
Ninety5five0's Avatar
Ninety5five0
Thats a pretty hefty cam. Whats your whole setup gonna consist of ?
Old Oct 26, 2006 | 07:41 PM
flyinghigh2k8
so far the cam, 70mm bbk thottle body, bbk headers and pro 5.0 shifter are what I'm puttin in ..... plus my sig.
Old Oct 26, 2006 | 09:00 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: Stanpower
OMG are Fning kidding??? There is no way he can use a set of stock springs off a set of E7's with that cam, hell they are not even really good enough for a stock cam. He would have valve float at 4000 rpm. Please don't try and pawn off your crap like this, he could very well hurt the motor if he followed your advice.
ORIGINAL: flyinghigh2k8
I would call Comp and see what they say, I have had very good luck going off thier advice on springs.
Old Oct 26, 2006 | 09:06 PM
JD1969's Avatar
JD1969
I thinbk that without and intake and heads your not going to see much performance gains. Heads are the big restriction on these engines. I am not saying you won't gain power, you will, just not much. Your looking at a cam that makes power in the 5-6000 rpm range, and heads and an intake that stops flowing at 4800-5000. The key as always is to have a matched combo.
Old Oct 26, 2006 | 10:00 PM
flyinghigh2k8
alrite thanks alot well what kinda heads and intake would you suggest, post some links please
Old Oct 26, 2006 | 10:15 PM
JD1969's Avatar
JD1969
It really depends on your budget. On the cheap a set of GT40's with a top notch valave job and a Cobra (or Explorer) intake is a good choice. If you have some coin to spend then the Trick Flow top end kits are great and the Edelbrock stuff is good as well. What are your goals and how much do you have to spend?
Old Oct 26, 2006 | 10:26 PM
flyinghigh2k8
well i'm pretty much goin from pay check to pay check with every upgrade haha. I've heard good things about trickflow though. I'm pretty new to this ****, but I'm pretty into it and learning alot fast. I've only had the stang 2 months.....and love it
Old Oct 26, 2006 | 10:37 PM
gspfunk's Avatar
gspfunk
You will likely have piston to valve clearance issues w/ the stock bottom end. There's a lot of other mods you should probably look to for getting the most out of your current setup. Like was mentioned above, that cam will not do you much good if you don't have some higher flowing heads and a better intake.
You'll want a better mid pipe to go w/ your flows and headers. You'll need a larger MAF. You won't need a TB that big until you've done the head swap.
I have done a LOT of research before buying parts and have still made plenty of mistakes during my build. Try to find out as much as possible before throwing money at parts and it will payoff in the end. Online articles are priceless and remember that you can't always trust what people post on forums...not this one in particular. You'll learn who knows their stuff as you post.....
