Computer problem
Old Oct 25, 2006 | 09:41 PM
Arno's Avatar
Arno
Default Computer problem
Took my 89 5.0 to the shop to see if it was throwing any codes. They hooked it up and nothing.....they tried two different systems and still no response from my computer, as if it was not there. I bought the car recently and was runnig down the idle problem. Any ideas why my computer is not being recognized?
Old Oct 25, 2006 | 10:23 PM
Joel5.0's Avatar
Joel5.0
Default RE: Computer problem
Possibilities:
- Bad ECM
- SIGRTN wire open
- Wiring problem (STO circuit)
You might want to check the problem description and how to check for a "No Codes" condition at http://fordfuelinjection.com/index.php?p=44 ....the results of the tests will give you the information to ID what's at fault. My 2¢.
Old Oct 25, 2006 | 10:31 PM
grabbem88's Avatar
grabbem88
well i had this problem also swapped ecms now everything works....go figure huh?
Old Oct 25, 2006 | 10:58 PM
Arno's Avatar
Arno
This should do the trick, thanks for the link.
ORIGINAL: Joel5.0
Possibilities:
- Bad ECM
- SIGRTN wire open
Old Oct 25, 2006 | 10:59 PM
Arno's Avatar
Arno
Where did you get the replacement ECM?
ORIGINAL: grabbem88
Old Oct 25, 2006 | 11:04 PM
grabbem88's Avatar
grabbem88
lol junk yards and swap meets.
Old Oct 26, 2006 | 12:22 AM
aode08's Avatar
aode08
BAD ECM
Send it out for repair !
$49-60 repair, takes 5 days to get back.
Old Oct 26, 2006 | 12:24 AM
grabbem88's Avatar
grabbem88
where the hell is this at?....ford only part,and yes they still control the part number i have asked many ford shops
Old Oct 26, 2006 | 01:15 AM
Arno's Avatar
Arno
Do I have to match the same year, or can I use any 5.0 Fox?
Who does the repair?
Old Oct 26, 2006 | 01:20 AM
grabbem88's Avatar
grabbem88
if auto any auto mass air car...manual any auto/man mass air car...89-93....88 cali...no 94/95's
