First Modification?
I'm thinking about a new Clutch, What kits do you recommend?
Then i'm thinking 3.73 Rear end gears Then CAI Exhuast And headers Ignition Engine Building time :) |
RE: First Modification?
Dont forget a 65 or 70 mm throttle body and 75mm MAF sensor. Get a fuel pressure regulator too so you can play with the air/fuel mixture. Get a bigger fuel pump while your at it. oh and get electric radiator fans and new spark plugs and MSD blaster coil.... hope this helps.
if it were me the very first thing i would do is an offroad h pipe and a good set of muffs, it will free up some good horse power. the clutch i would reccomend is the ford racing HD clutch with a steeda cable and quadrent. thats what i put in mine, its great.
nice ass.
i'm thinkin 3.73s then X pipe and mufflers
I went exhaust & 3:55's replace the clutch when it goes mike has 98k on it & is just starting to go.
cold air intake first followed by headers and exhaust then go for the gears and clutch.
