vibrations
Old Oct 27, 2006 | 02:06 AM
4eyesarebadass's Avatar
4eyesarebadass
Default vibrations
when im in 3rd and 4th gear around 3500+ rpms i can feel horrible vibrations through the shifter and the car shakes a bit? anyone have any ideas?
Old Oct 27, 2006 | 02:14 AM
92hatchLX's Avatar
92hatchLX
Default RE: vibrations
Do you have gears?
Old Oct 27, 2006 | 02:28 AM
4eyesarebadass
nope
Old Oct 27, 2006 | 02:55 AM
8Mustang8's Avatar
8Mustang8
mine kinda does that too, mines the flywheel i got eatin up a little when the starter started to fall out, i still have replaced either of them. anyone know how hard it is to replace the flywheel, i know the starter is a piece of cake but i'm worried about the flywheel
Old Oct 27, 2006 | 05:39 AM
mustangtt89's Avatar
mustangtt89
Couple thinks drive shaft
Cooling fan or clutch
Old Oct 27, 2006 | 08:44 AM
Stanpower's Avatar
Stanpower
It could be a trans mount or u-joint......Good luck
Old Oct 27, 2006 | 10:14 AM
4eyesarebadass
thanks
Old Oct 27, 2006 | 10:47 AM
7upedition's Avatar
7upedition
ORIGINAL: Stanpower
+1
Old Oct 27, 2006 | 01:23 PM
GaryBisiniere's Avatar
GaryBisiniere
i hate to be the dude with the bad / hard news but i got the same problem. dropped the tranny and found that the imput shaft moves and the pilot bearing just wobbles around. to fix the imput shaft i need to get a new bearing with the race. and then renistall a new pilot bearing.
hope this helps
Old Oct 27, 2006 | 01:57 PM
4eyesarebadass
gary, thats what i was thinking it might be, im buying a new trans this week anyways, so hopefully no more problems. thanks for all the advice guys.
