converter
Old Oct 29, 2006 | 02:31 AM
OJMiles's Avatar
OJMiles
Default RE: converter
3800-4000 stall for street/strip ? hrm... whatever!
call Andre at Edge Racing Converters - www.edgeracingconverters.com
Old Oct 29, 2006 | 02:45 AM
smbikes's Avatar
smbikes
Default converter
im going to get a new converter and wanted to know should i get lockup or nonlock , it will be about 3800-4000stall and will be street strip
Old Oct 29, 2006 | 11:18 AM
smbikes's Avatar
smbikes
whatever?? i need a 3800 -4000 stall , i know a lot of guys with them around here
Old Oct 29, 2006 | 11:20 AM
2 kwik's Avatar
2 kwik
I ♥ Acer
the cam you have rpm range starts at around 2800 if my memory is correct
Old Oct 29, 2006 | 11:27 AM
smbikes's Avatar
smbikes
it may say that but i dont belive it , my dyno dont start to flow till 3892 rpm , off the line i cant even spin a wheel
Old Oct 29, 2006 | 11:30 AM
2 kwik's Avatar
2 kwik
I ♥ Acer
whatelse is in the engine,because you my friends have some miss match parts to kill your bottom end..what was the cam degree'd in at?
Old Oct 29, 2006 | 11:31 AM
7upedition's Avatar
7upedition
hmmm... most guys run 3000-3200.... but each one has amind of its own.... good luck and i've also heard great things about this andre guy, no personal experience but sounds good.....
Old Oct 29, 2006 | 11:34 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: OJMiles
Whats wrong with a 4000 rpm converter on the street? I have yank 4000 and drive it on the street all the time, it's a lockup and is just fine. If his combo (and I have no idea wht his combo is) needs a stall that high, then why not. A lock up will give him the ability to drive it on the street and not kill it with heat.
Old Oct 29, 2006 | 11:35 AM
fourfivefour's Avatar
fourfivefour
ORIGINAL: smbikes
You better get a giant trans cooler with that large of a torque converter. I don't recommended long street driving with a converter that large. Your converter will be constantly slipping on the street and generating heat that will destroy the trans. Only when you hit 4k rpm's will the converter lock up and stop slipping. You are not going to cruise the streets at 4k r's.
I don't know if the lock up converter would help. Call some torque converter/trans builders and ask them if the lock up would help.
From my past experience I have seen several people smoke many a trans because they were running too high of a stall speed on the street cooking their trans to death.
Switch to a stick and you can drive in 1 st gear all day with no problems. If you want to run an auto like described stick to the track and very very short drives.
Old Oct 29, 2006 | 11:38 AM
2 kwik's Avatar
2 kwik
I ♥ Acer
jd...for a dd a 4000 builds a ton of heat even with a large cooler granted in the lock up it is easier to live with on the street...in my opinion a strip shift kit is need for a more positive shift
